Guessing game
Guessing game
The door lock button on my car key keeps falling out. Called into Toyota dealer today for a replacement key....
How much?
TORPC
Re: Guessing game
£120.00
Fixes: 188
Re: Guessing game
Second mortgage?
TORPC's guess sounds a bit low to me.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Re: Guessing game
Would you believe £140...for a key
Fixes: 188
Re: Guessing game
Yes I would and I would expect it to be made out of Platinum for that money.
It's ridiculous.
TORPC
Re: Guessing game
Yes I would believe it, as my brother - in - law had to have his replaced back last year
However he since found out ther are cheaper way(s)
Start by looking @ http://forums.anandtech.com/archive/index.php/t-2056484.html
Hope this helps
mwarby
Re: Guessing game
Suppose it depends if it's just a key, or a key and 5/10 mins hooked up to the diagnostic computer to program it in
Fixes: 250
Re: Guessing game
Just the fob was over £60 for my old Nissan Primera.
Thankfully I had separate key cover for the two times it had to be replaced costing me a total of £30 in premiums rather than the £130 appx it should have been.
Forum Moderator and Customer
Fixes: 12
Re: Guessing game
Quote from: Petlew
How much?
Quote from: Petlew
Cheaper to go to the local scrap yard and get a scrap key for its plastic parts. Take home, sap circuit boards and transponder chips and your done.
I did this recently. My cost £1, New key at dealers: £300 + vat.
Re: Guessing game
Car spares are an unbelievable price Roll eyes
Infinity
Seasoned Pro
Re: Guessing game
I checked out the cost of a non dealer replacement key (2nd spare) for the Hybrid Jazz, popped into a local key cutter shop, didn't look up to much from the outside.
But the chap in there produced a small black box, and inserted my Jazz key into a slot, and up popped the details of the electronics built into the key.
I was thinking probably around £30 !!
As above, £120 for a replacement key, and that wouldn't even have central locking ability !
Not much of a discount on a Honda supplied replacement key.
Re: Guessing game
As a post script to this; the Toyota dealers answer to my problem, that since in any other respect the key was functioning as it should except for the loose button, was a behind the hand whispered, "a piece of Sellotape wrapped round the key".
And that from a world class organisation!!
However, what I actually used was a sliver of Dymo tape a couple of mm larger than the button, which seemed to me much more "adhesive" than Sellotape and, I have to admit works quite well, and easily replaceable if it begins to get unstuck, even if it is bright yellow.
TORPC
Re: Guessing game
& saved yourself a fortune Wink
Infinity
Seasoned Pro
Re: Guessing game
Quote from: Petlew
Was a spare key supplied with the Car ?
If so, could you swap the keys ?
My spare keys go into a drawer, and never come out !
Must say I've never had a problem with a Car Key, but I do only place the key, and a hanky into a jacket or other pocket.
Coins go into another pocket.
At least with some of the modern car keys, the bit you insert into the lock, can flip out of the way when out of the lock, for protection of the electronics contained.
And of course, protects your pocket linings too !
Re: Guessing game
Is this the key fob that is the problem rather than the actual physical key that's the problem?
