Google Maps - very odd loading problem
Fixes: 62
We were looking up a satellite view location on my better half's PC (running XP) and the friend using it had selected Internet Explorer as that was what they were used to.
The loading rate was absolutely abysmal so I started Firefox and it was back to normal speeds. I can't believe that was the effect of adblock on Firefox so does anyone have any other ideas
Re: Google Maps - very odd loading problem
how does adblock for firefox affect internet explorer?  would it even work?
Fixes: 62
To clarify
Did adblock on Firefox block a load of rubbish which slowed down Internet Explorer
NorthEasterner
Wouldn't think so because I wouldn't think Google would advertise
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 298
could be something along that lines that Google have optimised it for Firefox / Chrome?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
I believe Google out right stopped supporting IE9 and earlier. I believe IE8 is the latest version on XP?
Chrome/Firefox will be able to provide extra functionality which IE on XP just can't provide, and it'll be this extra functionality which gives the performance boost.
[edit]Found a link http://googleappsupdates.blogspot.co.uk/2013/11/end-of-support-for-internet-explorer-9.html[/edit]
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
