Good for a chuckle...
I know there are forum members who like a chuckle. The following link is for the Amazon customer reviews for the largest usually available Swiss Army knife. Some real wags in here...
http://www.amazon.co.uk/product-reviews/B000R0JDSI/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Fixes: 60
Re: Good for a chuckle...
As someone said, he aught to write a book....or take it on stage. Grin
Customer and Forum Moderator.
Fixes: 9
I Liked the comment about "No trepanning tool !" for the Brain.
