Gas or electric kettle
Fixes: 9
Considering how many times we use a kettle in a day the total for a year will be at least a thousand per year.
If you have the option which would be the most economical kettle to use........ Gas or Electricity ?
Cash wise would it be worth switching to the most economical one or is the savings not worth the hassle ?
I guess this is a good question for all you mathematicians out there !
Re: Gas or electric kettle
Look at your bills and compare the price per kwh. My gas is a LOT cheaper.
Though I guess an electric kettle is probably more efficient in transferring heat to the water.
jmd
Never seen a gas kettle.................. Tongue Wink
But I use a small electric kettle so only heat what I need.
Midnight_Caller
Gas Kettle
Bojangles
Factor into the equation that gas kettles last for years whereas electric kettles seem to need replacing every so often. I've never been able to keep one for longer than 18 months or at most 2 years.
I would imagine that gas has to be cheaper. I use a gas tumble dryer and that is certainly more economical from what I've read.
itsme
@midnight
Where does the gas plug into and how do you light them. As the kettle is suitable
Suitable for gas hobs,solid,radiant ring and ceramic electric & induction hobs
why are they referred to as gas kettles?
pierre_pierre
Lots of differnt ones here, http://www.google.co.uk/products?q=judge+kettle&oe=utf-8&rls=org.mozilla:en-USShockedfficial&client=firefox... I have the Judge Helequin and dont often use use, might now.  I have a gas Hob and electriv oven, always keep the gas kettle in case of power cut
