Gadget freak Fodder
Fixes: 116
Gadget freak Fodder
A dual processor equipped torch http://cfx.supertorch.com/en/index.php ......I want one Cool
I've just bought one of these and it's excellent Smiley
Now I have to put the brakes on for a bit Sad
Customer and Forum Moderator.
Fixes: 234
Re: Gadget freak Fodder
you got a ps4 yet?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 116
That's one gadget I can pass on at the moment.
I have quite a few PS3 games barely started on.
Quote from: Strat
I expect that just means it has a couple of chips stuck on a board.
Rather than having a suggested/hinted dual core cpu.
Fixes: 10
Dual processor torch? What on earth are you going to run on that and why?
<clicks link>
Oh... i seeee  Cheesy
TORPC
next them there duel preprocessed  torches will report back to base how many time & for how long they were used each time Roll eyes Cheesy
Before you know it they will be quad core Cheesy
beeceegee
the torch is a bit of a con....
http://budgetlightforum.com/node/28031
(yes there really does seem to be a forum dedicated to the discussion of torches  Huh )
TORPC
I would prefer to on the fly save to SD or similar card or internal memory
Other than than that a nice piece of kit to add to you portable tool kit(s)
Fixes: 10
Quote from: doris
I want one of these, I don't know why But I do...
http://www.maplin.co.uk/p/dualscan-a4-portable-handheld-scanner-with-ocr-software-n86qa
That'll be the secret agent inside you wanting to break out and then break into some super secret office, scan some records and then leggit.
Unfortunately nearly everything is kept on computers these days so you'll need to be a great hacker too  Crazy
TORPC
Mission not so impossible, if you get lucky, finding the right credentials Roll eyes Cheesy
How about a Boeing phone Strat?
Now Zen, but a +Net residue.
TORPC
If the phone is tampered with, it automatically deletes any data and renders itself inoperable
No good for anyone who frequently forgets their login  credentials
Or if they leave it on the side & the kids get a hold of  it Tongue
I'm happy with the tool I made last week.
A long stick with a bit of wood screwed on the end.
It was perfect for cleaning the moss and rubbish clogging up my roof guttering.
I suppose I could screw a torch to the stick then I could do it at night. Smiley
Midnight_Caller
Quote from: doris
I know why I do want one with me having dyslexia, I have seen them cheaper elsewhere, but I do want one!
