Fuses for a standard plug
- General Chat
- Fuses for a standard plug
24-05-2010 4:18 PM
Any one know where I can get 1 AMP Fuse for a United Kingdom standard plug?
Re: Fuses for a standard plug
24-05-2010 4:26 PM
24-05-2010 4:39 PM
Customer and Forum Moderator.
24-05-2010 5:01 PM
24-05-2010 5:14 PM
24-05-2010 5:16 PM
1A Shaver Adaptor Fuse 2 Pack
* 20mm x 5mm
* Conforms to BS646
* Supplied in pack of 2
24-05-2010 5:17 PM
Quote from: artmo Bought some new fuses a few weeks ago and 2A were the smallest on sale together with 5A and 13A. May I ask why you need a 1A one?
current UK sizes are 3, 5, 13A 25.4mm long, 6.3mm dia
24-05-2010 6:22 PM
Would both of these fuses blow?
a) 120mA fuse
b) 3A fuse
24-05-2010 6:55 PM
24-05-2010 8:32 PM
[My Bold] The smallest on sale in Middlesbrough is 3 AMP Fuses. 13 AMP Fuses should only be used in washing machines or irons. The highest AMP Fuse that should be used these days is 5 AMP Fuse for crt monitor or crt TV, for TFT monitor the maximum is 3 AMP Fuse, me LG 22" TFT TV come with a 10 AMP Fuse wat went in the bin, and replaced with 5 AMP Fuse.
The reason way I want 1 AMP Fuses is for my lamps, I bought a lamp from a lighting center and it had a 13 AMP Fuse in it, the 13 AMP Fuse went in the bin and replaced with 3 AMP Fuse, but a sparky said that I should use 1 AMP Fuses in lamps these days.
Thank you pierre for the link.
24-05-2010 9:17 PM
24-05-2010 9:34 PM
24-05-2010 9:38 PM
24-05-2010 9:46 PM
24-05-2010 9:48 PM
