Fuel consumption
Re: Fuel consumption
Quote from: journeys
@petlew:-  fuel consumption of say a 54 seater coach in MPG
As expected the answer is quite complex but:
The two 57 seater Plaxton Volvo engined coaches in the fleet (we don't have 54's after all) is that they do by rough rule of thumb 7mpg.
The fleet varies between 5.5mpg for 72 seater tri-axle to 3mpg for a 110 (with standing) seater tri-axle double decker.
@petlew, thank you.
