Fuel consumption
- General Chat
- Re: Fuel consumption
Fuel consumption
26-05-2011 8:50 AM
26-05-2011 10:01 AM
Whichever you choose, its likely to be far better if expressed as mpg per passenger than you could do in most cars.
26-05-2011 10:33 AM
26-05-2011 10:44 AM
Quote Passenger Rail
The tables in section 6 of the RSSB source provide 2,900 GWh of electricity at the substations and 4700 GWh of diesel to the traction units.
Hence the total primary burn amounted to (2,900 x 3 + 4,700 x 1.1) = 13,870 GWh, equivalent to: 286 million gallons of diesel.
There were 43.2 billion passenger km. Hence we have:
(43.2 x 109 x 0.625) / (286 x 106) = 94.4 passenger-miles per gallon.
In comparison an express coach returning 10 miles per gallon and with as few as 20 people aboard would return 180 passenger-miles per gallon after allowing for refinery and transport losses of 10%. (Note, the RSSB suggest express coaches have a 60% occupancy ,equivalent to 30 people for a 50-seat coach). The corresponding system wide fuel consumption would then be (43.2 x 109 x 0.625)/180 = 150 million gallons, or 573 KT diesel or 7,272 GWh.
26-05-2011 10:52 AM
26-05-2011 11:24 AM
I suspect that travelling by car (even singly) or plane uses less fuel.
26-05-2011 12:44 PM
However the fuel consumption figures per passenger may make for different reading.
What about the electric high speed trains - they should be more efficient than diesel, but remember you can't do a mpg comparison.
26-05-2011 12:51 PM
Quote from: geofftswin electric high speed trains - they should be more efficient than diesel,
I'm pretty sure I read something very recently that explained that diesel-electric is significantly more efficient than straight electric, mainly due to generation/transmission being pretty inefficient.
(what we call diesel trains are almost invariably diesel-electric in practice)
And that's at the same speed.
26-05-2011 1:01 PM
26-05-2011 1:15 PM
Quote from: Petlew the type of train that journeys was referring to in the OP uses direct underfloor diesel drive.
Indded, I think it's actually a hydraulic trasmission.
I was referring more generally to diesel trains, not just the Sprinters.
26-05-2011 7:25 PM
Quote from: journeys was after a caparison with a coach say a 54 seater.
Since I work for a coach operator, I'll ask them (I drive'm not worry about the how much it costs) and we do run a couple of 54 seaters.
However, it is a small company and may not have the interest in complex fuel usage figures, but I will ask the question.
Er! exactly what question are you asking?
26-05-2011 8:02 PM
http://www.transport-watch.co.uk/transport-pdfs/transport-fact-sheet-5.pdf
and you will see the Introduction, explaining the figures....
then scroll down a bit and see this...
Passenger Rail returned the equivalent of 94 passenger miles per gallon
and a bit further down ... this...
In comparison express coaches with 20 passengers aboard would provide 180 passenger miles
per gallon
The above figures are for the "System Wide" figures .....
26-05-2011 8:49 PM
@shutter:- Thanks
Question came up at a meeting on the proposition of re-opening a 'light' railway line, one of the discussions maintained that train travel (fuel consumption only) was far more efficient than road travel
Although I'm pro train travel and would endorse the proposition, I felt using fuel consumption as an argument was misleading.
I wanted to go back to the proposer with some details.
The re-opening of this line has been discussed for 30 odd years, it was basically written off as no go because of H&S. What prompted the meeting was the re-opening of the line (tunnel lighting and all) as a cycle way.
26-05-2011 9:01 PM
After closure, it lay derelict for a while, then the local council decided to tarmac the trackbed and turned it into a footpath.... they are at present "converting" it into a "guided bus route".... at enormous cost.... rebuilding bridges and underpasses for the bus to run unhindered... quite a lot of opposition from people who`s gardens back onto the "track"... It is conceived as a way to get motorists to abandon their cars, to get to Fareham for shopping , and off to the rest of the UK road network.! ,< HA HA HA>.. in order to relieve congestion on the main route... If you are interested, Google maps for Gosport, and directions to Fareham... then go to satellite view... and you will be able to see the old track bed route...
If the council had really thought about it,... they could have leased the land , and probably taken shares in. a bid to re-open the line as a Heritage Line... to bring visitors INTO Gosport... ... the similarity of location to the SWANAGE Railway, cannot be missed.... and that seems to be doing very nicely thank you...
26-05-2011 10:26 PM
