Freesat tuner/recorder
Fixes: 10
We;re getting a little fed up with the breakup of the Freeview signal when pressure is high so I'm considering buying a Freesat box with dual tuner and recorder (previous owner of house left a Sky dish with dual signal feed).
Any recommendations? (I've got a box in mind but am interested in what others suggest)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: Freesat tuner/recorder
We've got a Humax FreeSat PVR, works well.
Fixes: 10
Which model?
Fixes: 174
I have the Humax Foxsat HDR.
The advantage of this box is as well as Freesat you can switch to non-freesat mode and tune other stations.
If you have a dual LNB and run 2 cables you can record 2 different programmes or record one and watch another.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
coolkat
What I want to know is, this new box for £9.99 can you link it to a freeview box,the one where you can record,switch back to unseen programmes and all that jazz Crazy Undecided Undecided Undecided
Humax here too - Humax HDR 1000s!
Just connect up the feeds and away you go!
Check out http://www.humaxdirect.co.uk/ for latest prices and offers.
Geoff,
York.
Fixes: 10
That's really helpful that you are all saying Humax - I was looking at their latest model, the Humax HDR-1010S
Fixes: 9
We Have had a Humax for years, apart from the odd  minor problem caused by updates it has been excellent and we would certainly get another one, it would be useful if they included Wi Fi but the latest model has something that I would find very useful,
'Humax HDR-1000S Connectivity
On the back are two satellite LNB inputs (one for each tuner), HDMI and optical digital audio outputs, an Ethernet port and a second USB port. Scart, composite video and analogue stereo outputs are also provided, useful if you want to make copies of anything you’ve recorded. A Common Interface slot is found on the side.
Read more at http://www.trustedreviews.com/humax-hdr-1000s_TV-recorder---set-top-box_review#tpvmGBpgXuEGcJ40.99'
Fixes: 174
I have a Fortec Star Passion+ in a cupboard upstairs which failed just out of warranty (the Fortec Star not the cupboard)
I replaced it with the Humax and have been satisfied with it.
I have loaded custom firmware on mine which allows me to access it over my network and configure it amongst other things.
Fixes: 348
I have a panasonic freesat box which is great, but unfortunately they don't make freesat boxes anymore.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 10
Quote from: gleneagles
Err... I don't think the Humax HDR-1000S is the latest model! http://www.humaxdirect.co.uk/product.asp?ProdRef=10112
DaveyH
Seasoned Pro
Fixes: 9
The  only difference between the 1000s and 1010s (apart from it being white) is the inclusion of WiFi in the later
dick:quote
Fixes: 9
Thanks for that, even more interested in replacing my current model for that one.
With the cash back offers you can get for Sky, it would cost virtually the same to have the basic Sky package for the year as buying a Freesat HD box with record features.
Fixes: 174
I won't have Sky in my house.
