Forum rules
Fixes: 9
Forum rules
As I understand it you cannot quote a previous reply when responding to a post, in all fairness a red warning usually appears to indicate a new post has been made prior to posting your reply but in some cases this does not always work which can end up looking like you are critical or opposed to the last post made when in fact you may support that point of view.
Fixes: 62
Re: Forum rules
you can always edit your post to make it clear
Fixes: 10
Re: Forum rules
For how long?  Cheesy  Wink  Crazy
Fixes: 62
Re: Forum rules
a day and if you haven't bothered by then it obviously wasn't too critical
Fixes: 9
Re: Forum rules
Perhaps it's just me but even when I have posted something it's not always that quick to get back on the site.
I Accept that a day is more than adequate as it has never taken me that long to get on again
Smiley
Re: Forum rules
Rather than quote the previous post; I usually find the well known @name of poster with or without the post# works very well. You can also edit your post to add it if you find someone has posted in between.
Fixes: 9
Re: Forum rules
@Petlew,
That's a good idea.
Smiley Smiley Smiley
