Forum Ignore Filter
Forum Ignore Filter
Enabled
12 REPLIES 12
Fixes: 15
Re: Forum Ignore Filter
I find this a provocative post as it names another user !
The moderators should consider deleting it !
I don't see the point of it myself, it just looks broken to me. But if it worked properly then you wouldn't know who was blocked! However, to demo I guess some sample data is needed but it would have more polite to use themselves as the example.
Amended
Example now myself
Example is now myself
If I were to do this I'd have done it so that it looked like this:
Ignore Mook
G*** !
What do you mean @Anonymous? I'm not naming anyone, in the screen grab I've removed myself from the output so my post #3 doesn't appear as I have 'blocked' myself.
I've decided to ignore this topic, which seems to me the simplest way.
Fixes: 57
As it is getting silly, @petlew, I think I'll do the same, although the principle is interesting.
Thank you all for your valuable input...
The filter is up & running now.
Yes, this is getting silly, I don't have a clue what you are getting at @Anonymous so I'm not wasting any more time on this, there is nothing in my post that isn't in the forum.
Fixes: 15
@Anonymous
Thank you for amending it.
Smiley
