Form filler
Form filler
I have a lengthy set of forms to fill in. I would like to do this on the PC rather than by hand. Anybody suggest some free software for this?
Fixes: 62
Re: Form filler
If they are pdf forms then this will do it http://www.tracker-software.com/product/pdf-xchange-viewer and if they aren't pdf then use something like CutePDF to create them
Re: Form filler
Thanks Jim, I already have that but can't get it to do what I want, which is: to scan the forms and fill them in. At least not unless I upgrade to the full version (I guess)
I wondered if Adobe Reader may do it? my objection to AR is everything else that goes with it...!!
Fixes: 62
Re: Form filler
It does if you scan as a pdf then use the Typewriter tool is works fine - see this picture
The typewriter tool is under Tools, Comment and Markup Tools
Re: Form filler
Ok Jim I'll give it a try, thanks.
