For users of the PDF XChange viewer
For several months my employer has changed to submitting pay slips by email as pdf files. I don't have a problem with this if fact I think its quite a good move.
Instead of filing them in an email folder in Thunderbird as I am currently, I would like to save them directly in XChange viewer as a tabbed document, something like "sheets" in MS Excel.
Anyone know how to go about this if it can be done?
I suspect it may be available in Adobe Reader, but I currently don't have that on board.
Fixes: 62
Re: For users of the PDF XChange viewer
I am not sure what you want to do.
With PDF Exchange viewer as standard when you open multiple PDF documents they appear as tabs so if you save the files into a folder you can then open all as many files as you want using Windows Explorer
The only way to combine them is into a single pdf document as pages but as far as I know none of the free ones will do that
Thanks Oldjim, your last line was what I wanted to do. you put it better than I did.
Fixes: 71
I think you might need the paid for version to do this. For more information including a link to PDF-Tools see How do I merge PDF files using the PDF XChange Viewer. It looks like they offer a trial version.
David
mushy
PDF Binder is a free little program that can combine pdf's into one bigger pdf, no doubt there are others as well (think pdfmerge and pdffill but not tried them).
http://code.google.com/p/pdfbinder/downloads/detail?name=PDFBinder-v1.2.msi&can=2&q=
or
http://pdfbinder.en.softonic.com/
From there you could bookmark each page or slip within pdf xchange, maybe not tabs or sheets but easily viewable from the bookmarks.
Thanks gents, I'll take a look at all those links.
It is of course just a bit of tidying up housekeeping, I could easily carry on the way I'm doing it in Thunderbird, and will do so if any of these fail (or cost-a-lot!!) I just feel there must be an easier way that allows me to quickly compare pay slips in one click. Since I am paid weekly I tend to have quite a lot of them.
In fact Thunderbird operates tabs in the "inbox" now if that worked in individual folders then I wouldn't be looking any further.
Bit away from your original question, but PDFsam might be able to do it (it is opensource and has version for both MAC and Windows)
http://www.pdfsam.org/
allows the splitting up and merging of PDF files.
I receive some of my bills online (electricity and phone), I use PDFsam to split out the header pages, then merge all the bills into one for the year.
Actually its not journeys, I tried the other two but they didn't do what I wanted them to, the Softtronic one in particular tried to take over my PC with unwanted toolbars and search engines. it even changed my home page. It seems to have a number of legacy's around still to be removed.
