Firefox 4 is out
Fixes: 62
Firefox 4 is out
https://www.mozilla.com/en-GB/products/download.html?product=firefox-4.0&os=win&lang=en-GB
Just starting playing with it - the first thing I did was to move the tabs back to the usual position
77 REPLIES 77
Seasoned Pro
Re: Firefox 4 is out
I tried It last night, Don't like It under windows, Uses a lot of ram.
If life gives you lemons, make lemonade.
Fixes: 62
i didn't check how much the old version uses but this seems to start at 60MB and go up to about 150MB with a load of tabs open - given that I have 4GB of Ram that doesn't really bother me
Seasoned Pro
Its probably just me getting really moody with windows lately, I had two tabs open and all In was nearly hitting 1GB ram, Under linux I barely hit 512MB, I have 3GB Ram which Is fine for me, I'm back using Linux now though.
I do like how the new FF tells you how much cache your actually using.
Fixes: 62
where is that
Seasoned Pro
Now your asking LOL, I think Its under the advanced section, The bit where you can check off how Firefox connects to the web, Firefox updates, Add on updates etc, I think!! Cant remember exactly.
How quick is it compared to Chrome?
The only reason I'm *not* using Firefox is that I found it really slow, especially the amount of time it took to open first thing in the morning.
Fixes: 62
Quote from: Steve
Found it thanks
Seasoned Pro
Certainly boots up a bit faster jameseh and gets you where you want to go, I would say Its close to the speed of chrome, Close..
Quote from: Jameseh
I also find this, James, but it's fine for rest of the day.
Fixes: 12
So is it still leaking memory or not? - I had FF grind several computers to a halt years ago it would take up so much ram and frankly that was my reason for switching to seamonkey.
Chrome was also just as bad when I tried the initial beta.
That's exactly my experience too.  Sometimes I wonder if it is because I use a number of addons.  It isn't really a problem because for the rest of the day I just hibernate the laptop with FF loaded.
If Chrome was more configurable then it might be an option but I can't do without my menu bar.  Will not be changing to FF4 until I have to.
Well it looks like I am now forced to use FF, my main browser has up until today been Chrome (although I tend to have both loaded) but as of an update today, Chrome hangs on all flash, video, animated gifs, in fact any image or anything image like that isn't totally static.
I'm fresh out of ideas.  Anyone?
Fixes: 62
Just tried opening 25 tabs and it was very quick - memory usage went up to 450MB  and then as I closed them memory dropped back in a few seconds
I haven't noticed memory leak in the past though
Seasoned Pro
Quote from: fourfourdevon
This Is why under Linux you should not use Chrome but Instead use Chromium. Wink
