FireFox problem
FireFox problem
Anyone else had this I wonder:
Blank web pages appearing in spite that the URL status said loading was "done" (if you have that particular FF add-on)
This did not effect all pages for instance PN Community opened normally, but any forum selected was blank. PN Member Centre was normal but BB Speedtest was blank. My initial thoughts were that PN were having a problem, but a trawl through my bookmark list found around 1/3 to 1/2 of the sites were coming up blank the remainder being normal.
A penny dropped when I remembered that this issue seemed to follow a brief earlier in the day un-requested interference from FF "Speedfox" add-on. Speedfox was deleted (not disabled) from the add-on list...no more problem.
Re: FireFox problem
PS. Ironically, since the deletion of SpeedFox web browsing has become decidedly quicker.
Razer
Re: FireFox problem
I don't and never have used this addon you talk about. I do, however, occasionally get blank pages.
Re: FireFox problem
Nor did I think I had, I never asked for or intentionally installed SpeedFox, it just "appeared. I suppose it might have installed by failing to untick a box when installing or updating something else, Java updates are rather fond of that sort of thing. You might check if you've got it though. Quickest way, check the drop down list of search engines if its there it probably sneaked in behind your back.
Razer
Re: FireFox problem
I definitely don't have it. I can't think where you might have got it from. Very annoying either way, eh? Finding things on your system you didn't ask for.
Midnight_Caller
Re: FireFox problem
Can any one tell me why sites fink that I am using Internet Explorer v6 when I am using FireFox v18.0.2 ?
I tried removing FireFox, then reinstalling it and still getting the same problem.
Plus I am getting the same problem with FlashPeak SlimBrowser, any one know why this is happening ?
The only Browser that it does not happen with is Google Chrome what I hate, and I do hate it!
Oh I forgot I do have Internet Explorer v6 on my computer, I can not upgrade it to Internet Explorer v8 it causes problems so 8 is out.
Fixes: 17
Re: FireFox problem
I'm sure there's at least one add-on that gives you the ability to change the user agent string.
RPMozley
Fixes: 5
Re: FireFox problem
If it's not an add-on that's doing it, then stick in the location bar
about:config
and search for "useragent". See if anything comes up regarding Exploder v6
That's RPM to you!!
Midnight_Caller
Re: FireFox problem
@ejs, There is no add-on
@RPMozley, There is no reference to Internet Explorer v6 in the list.
Thank you both
VileReynard
Seasoned Pro
Fixes: 10
Re: FireFox problem
Try http://whatsmyuseragent.com/
I get
Your User Agent String is:
Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:18.0) Gecko/20100101 Firefox/18.0
Your IP Address: xxx.xxx.xxx.xxx
(That's firefox 18.0.2)
Midnight_Caller
Re: FireFox problem
Mozilla/4.0 (compatible; MSIE 6.0; Windows ME) Opera 7.11 [en]
Your IP Address:  xx.xx.xxx.xx
Huh
RPMozley
Fixes: 5
Re: FireFox problem
Do you even have Opera installed? Huh
Anyway, the only other thing that could possibly change your UA string is some sort of security software. Maybe an idea to check on what you have.
That's RPM to you!!
Midnight_Caller
Re: FireFox problem
No I don't have Opera installed, installed is:
Mozilla Firefox v18.0.2
Google Chrome
And that's it!
