FireFox again...
FireFox again...
Anybody else noticed that with the current V19 FF has annoyingly lost the ability to restore previous versions.
Right click the FF icon, select "restore previous versions" and wait while it searches, then "there are no previous versions available"
Fixes: 168
Re: FireFox again...
I just used the task manager to quit FF19 and when I restarted was presented the Restore option page with a list of all previous tabs/windows that were open.
Forum Moderator and Customer
Razer
This must be some OS specific thing. I see no such option, and never have.
alanf
That's not a feature that I am aware of either. I use Windows 7 and 8.
I have just discovered that iPlayer doesn't do downloads initiated by Firefox 19. When attempting to do so I am asked to install iPlayer Desktop (IPD) which is already installed. When I click on the button to install I endlessly get the modern equivalent of the hourglass. I uninstalled IPD and tried again. Same result. Then trying IE9  I was prompted to install IPD and Adobe Air. They installed. Testing IPD it worked with IE9 but not FF19.
Checking iPlayer Help I see that there is a similar known issue with Google Chrome. http://iplayerhelp.external.bbc.co.uk/help/announcements/desktop_chrome
Firefox 19 is not listed as a browser supported by iPlayer. http://iplayerhelp.external.bbc.co.uk/help/using_bbc_iplayer/browser_os_support
Waldo
Quote from: Petlew
That sounds to me to be something to do with Windows; restore from backup or restore point, perhaps?
If you mean restore a previous session, that can be set from Firefox preferences.
Fixes: 10
Interesting point to note regarding firefox..
IF you find your .css files are being ignored, background images aren't showing etc, be sure that the webserver is outputting the correct mime type of text/css and nothing else like text/html for the css file.
Working on one website last night that little glitch had me going round in circles for many hours. IE displayed the page perfectly but FF refused to accept that a file with a .css extension could possibly be css data. Eventually I found the problem (.htaccess with a AddType for .css - simple fix was another .htaccess file in the right folder) but it was a mega pain.
