Finger nails
Fixes: 186
Re: Finger nails
I'd like to say I don't have any.
However it can't taste any worse than the stuff I have in the bottle.
This conversation is going downhill quite quickly  Embarrassed
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 186
Re: Finger nails
Quote from: Mav
On the plus side you'll not have any more problems with the end of Sellotape rolls Wink
...and picking up things like coins.
People with normal nails don't know the many problems of not having them. It can be so frustrating.
Fixes: 250
Re: Finger nails
One of the down sides is getting my nails caught when dressing - I've had a few painful moments and that's when SWMBO steps in with her clippers.
Forum Moderator and Customer
Fixes: 21
Re: Finger nails
How`s it going, Strat?
Been down to the local Nail Bar, yet ?  Huh
Fixes: 186
Re: Finger nails
Something like 3mm now.
Problem is I don't know what a 'normal' nail length is and measuring men's nails in the street doesn't seem to go down well.
I tried Googling it and the only result I got was "Get a Life"
TORPC
Re: Finger nails
I let mine grow until approx 4 - 5mm
TORPC
Re: Finger nails
Looks like our good friend Google is having an off day Tongue
Fixes: 250
Re: Finger nails
Quote from: Strat
So that was you, was it strat? Wink Cheesy
My daughter proudly showed off her nails yesterday. Apparently she hasn't bitten them for several months and they are looking good.
Fixes: 186
Re: Finger nails
Yes it was Mav....and the fiver to get rid of me was much appreciated. I bought a Subway for lunch.
Ooo....can I say that Lips are sealed
As I've mentioned before my daughter does nails but I don't want to end up with purple glitter extensions.
TORPC
Re: Finger nails
Fixes: 21
Re: Finger nails
Quote from: Strat
Cheesy
Have a look at the pic of the guy with the black fingers.... in TORPC` linky... that is "about right".... men don`t need longer nails than the finger length... You will find that the "shorter" length, as in the pic, is adequate for scratching the posterior,  Shocked      or picking the proboscis !...      Shocked    without doing damage to either... and ... you will be able to pick up your change from the bar easier too ! ! ! ...
Cheesy Cheesy
TORPC
Re: Finger nails
Hand moisturiser for men never used any myself (SWMBO says I should)  Shocked Undecided
Fixes: 21
Re: Finger nails
So, Strat........ been down the nail bar recently?   or have you resurrected your belief in self canniablism ?   Cheesy
Re: Finger nails
I'm biting my nails waiting to know Grin
Fixes: 186
Re: Finger nails
I had a relapse Embarrassed
I'm trying again.....
