Finally an Ecommerce site I liked.
AlaricAdair
I needed some brass Munsen rings and posts for my current Barbecue project. I tried the local B&Q and various plumbers merchants to no avail so I set forth on the internet and eventually found a supplier in the UK. It was graphskill.co.uk Their e-commerce site works really well, easy to use, good supporting documentation on-line etc etc. It is as though someone has actually thought through how such a site should operate.
The are many major sites where it seems to objective is to annoy users. Does anyone have candidates for the list?
Now Zen, but a +Net residue.
5 REPLIES 5
picbits
Re: Finally an Ecommerce site I liked.
The B&Q and Amazon sites always seem to return loads of results that have absolutely nothing to do with the search query - I hate that.
Strat
Fixes: 515
Quote from: AlaricAdair
Munsen rings
As soon as I saw that name it triggered a vague and distant memory.
Thanks to Google I can now rest in the knowledge the memory was from my plumbing and pipe fitting days Cool
Customer and Forum Moderator. Windows 10 Firefox 90.0.2 (64-bit)
Champnet
Seasoned Champion
Fixes: 7
The use of quotation marks and arithmetic operators + and - may get you closer results.
I.E. "devolo powerline" +"500 Mbps"
Minivanman
Aspiring Legend
@picbits
Amazon are particularly annoying especially it seems if you have an account with them. You do an internet search for an item and Amazon pops up first showing you a completely unrelated item.
Sorry Amazon, I was looking for a 15mm brass isolating valve, not some new winter boots for the Mrs.
I have not failed. I've just found 10,000 ways that won't work.
Thomas A. Edison
picbits
Blimey - this thread was only 6 years old when it was resurrected Wink
