Filling out a Form
Fixes: 144
Filling out a Form
How can you fill out a form?
Easy
Get a form that's been filled in and erase all content in the boxes. Roll eyes
You can't fill out a form any more than you can fill out a hole in the road.
A form has spaces to be filled in with letters and numbers...right?Huh
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
Fixes: 19
Re: Filling out a Form
Correct  Cheesy
nadger
Q - Are you a pedant?
Circle answer Y or N
Smiley
Fixes: 144
@nadger It was you who pointed me in the direction of logbook loans within which was made a reference to filling out a form Wink
kmilburn
I think this statement sums it up....
[quote=http://www.openwriting.com/archives/2007/09/the_dove_dove_i_1.php]You have to marvel at the unique lunacy of a language in which your house can burn up as it burns down, in which you fill in a form by filling it out and in which an alarm goes off by going on.
randpwar
Along the same lines, I used to have a Maltese friend who said that alarm clocks should ‘go on’ when they ring not ‘go off’. I saw her logic
Thunderclap
Fill this form out is an Americanizm. But then you submit the form. Submit to what?
Q. Why did the candiate fail to get an interview with G4S?
A. He filled in the G4S application form.
Cool
How can you cut a tree down and then chop it up?
Geoff,
York.
randpwar
Drawing curtains works both ways though  Wink
Strictly speaking ...... you don't fill out/in a form. You merely apply a partial surface layer of ink in a patterned format on to a piece of preprinted paper.
Now Zen, but a +Net residue.
Fixes: 144
I happily concede to the wisdom of my honourable friend's interpretation Smiley
Quote from: AlaricAdair
Could you provide a similarly derived explanation for entering the required information on an online or electronic form please?
Call me 'w23'
Fixes: 228
Never understood why you score a try in rugby...
... surely that should be an 'achieve'. Cheesy
Forum Moderator and Customer
randpwar
My understanding is that originally putting the ball down behind the opponent’s try line gave your team no points but entitled you to try to kick the ball between the posts, thus earning points. Then later on, obviously, scoring a try became more valuable (in points terms) to kicking the conversion
Fixes: 144
And doctors work in a practice.......how long do they need to get it right Undecided
