File format converter
randpwar
I’ve recently bought a HTC Windows Phone 8S phone and have been trying to put my music collection on to it as the sound quality via its Beat’s Audio facility is superb. My collection has, in the main, been ripped from CD’s using a mixture of iTunes, WMP, Zune etc and some have unusual file formats (m4a from memory but not at home at the minute so I can’t check). When I copy the files to my phone sd card these files cannot be found on the phone. When I convert them to mp3 files, however, I can find and play them. I used Media Monkey to convert the files but find it a bit slow and not too intuitive. Hoping you can suggest other file convertors to do this for me
Thanks in advance
Rob
Fixes: 225
Re: File format converter
Although I have not used the option myself have you tried batch processing with Audacity?
Forum Moderator and Customer
Fixes: 19
What is the file format you are hoping to convert to ?
randpwar
mp3 seems to work  Smiley
Fixes: 19
Not tried it but.......
http://download.cnet.com/Free-Audio-Converter/3000-2140_4-10893961.html
Although this one
http://www.nch.com.au/switch/index.html
Might work for you, as it says it does "batch conversion"..
Razer
You would be better to re-rip the CDs and encode freshly to mp3 (if you must use that codec), otherwise you're transcoding, which is a bit like taking a photocopy of a photocopy.
