Figure this out.
Fixes: 9
Figure this out.
Is it possible to speak at normal speed for one minute, without repeating the same word twice but using words that must not contain the letter "A" ?
Answer tomorrow unless one of you bright folks comes up with the answer before then ! Smiley
alanf
Re: Figure this out.
Someone reading words (not definitions) from a dictionary of a language not based on the Roman alphabet? Greek? Japanese?
JamesM
Counting numbers ?
1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,30,40,50,60,70,80,90,100,200,300,400,500 ect
James
I thought you had it for a moment there, but you'll be repeating words.
Twenty one, Twenty two, etc.
JamesM
I did too James, I skipped the repateated numbers though by going from 20 to 30 and from 100 to 200, but after 900 you get 1000 which has an a. It works though if you speak very slowly  Wink
Fixes: 9
That was quick !
the answer was the numbers.
Depends of course on agreeing that twentyone, twentytwo, twentythree, etc are all single words !
Certainly some bright folk at PN.  Wink
Fixes: 10
Quote from: James
Ah but you're assuming the person is counting them as strings instead of integers  Cheesy  Grin
