turn on suggestions
Fiesta bulb replacement
- General Chat
- Fiesta bulb replacement
08-03-2013 7:25 PM
Fiesta mk6 (06 reg) , high level rear brake light, how on earth do you get it off to replace the bulb?
Re: Fiesta bulb replacement
08-03-2013 7:34 PM
Well, If your Ford Dealership won`t help...... Google will....
took me all of 10 seconds to find this...
http://forums.overclockers.co.uk/showthread.php?p=17680929
08-03-2013 7:42 PM
Lol, 98 Renault.... can anyone tell me how to...
08-03-2013 7:45 PM
Tried that, but it doesn't shift. The problem is that you can't see the springs because they are buried about an inch inside the frame of the hatch. Don't really want to bust something.
09-03-2013 1:41 PM
Doubt this is relevant but I upgraded the bulbs I had on a Ford Focus (Diesel) virtually impossible to replace them going into the engine bay from the top as there was always the chance of dropping the wire clip that holds them in place SO Jacked up and removed the front wheels, removed the plastic wheel arch covers thus giving me tons of room to do the job.
Never understood why some cars are such a pain to do the simplest job.
09-03-2013 4:14 PM
Quote from: gleneagles Never understood why some cars are such a pain to do the simplest job.
To create work for the dealers' service department possibly
09-03-2013 4:30 PM
It is the way the car is manufactured..... in the "olden days".... it used to be built UP from the chassis.... so everything was lowered onto the chassis....making DIY easy.... now the car is dropped down onto the engine .... no longer can you use a hoist to get that out... you need to put the car on a lift, and lower it out of the engine bay...
09-03-2013 8:25 PM
That'll explain mine then shutter. I have to take off the entire front bumper, radiator panel etc and lower it down from the mounts before pulling it out. It's a real pain of a job but possibly better than some other cars.
I agree though, there must be a better way of making cars so that they're easier to work on. VW have a large following for a reason..
