Fast Internet in Welsh Cowboy country? No problem.
- General Chat
- Fast Internet in Welsh Cowboy country? No problem.
30-07-2017 5:49 PM
Heol Senni in Wales is more remote than the middle of nowhere, distinguished by soldiers running around with the hill sheep.
However it is blessed with 28 mbps broadband.
Re: Fast Internet in Welsh Cowboy country? No problem.
30-07-2017 5:55 PM
Ah! But being cynical, if there is an army base close by then maybe BT will have been asked politely to put the infrastructure in for the benefit of the MoD
30-07-2017 5:59 PM - edited 30-07-2017 6:00 PM
@Minivanman posted that in a post 10 hours ago.
30-07-2017 7:00 PM
I posted and linked that earlier but however....
Our youngest daughters lives just south and on the edge of the Brecon Beacons in a little..... well not even a village and guess what, they get fibre.
It might not have been cheap for BT to beep sheep, but high speed broadband, no problem!
Don't limit the friends you haven't met with arguments you'll never have.
30-07-2017 7:17 PM
I have to say, it's a non-story really, two-way satellite broadband has been available to domestic and commercial users for years, often times a lot faster than ADSL before VDSL was brought out, and for those out in the sticks, it was that or dialup (or the "half-satellite" service where you sent uploads and your "clicks" out via Dialup, and received the data via satellite on a standard one-way dish), I guess the BBC just were having a no-news day so had to find "something" to publish...
The most well-known supplier of satellite internet is Tooway (hopefully PN won't be annoyed at my mentioning them!), decent prices for light users, not so much for heavy users, but, when there's little choice for those out in the sticks with no fibre, ADSL or 3/4G, it's worth looking at...
Heck, back on 2008 I was ever so close to signing up for them cos there was no decent ADSL where I lived at the time!!
30-07-2017 7:17 PM
I bow to your thread
30-07-2017 7:26 PM
There was also a subsidy, but only for those who could confirm that BT were not able to connect them by a certain date..... which they said they would, never did, so never got the subsidy........ and I tried after they promised me fibre by March 2014 and only now with the help of plusnet's FTTP trial am I finally up and running.
So well done plusnet and "yah boo sucks" to BT.
30-07-2017 7:43 PM
@twocvbloke thanks for that tip!
Last time i looked at satellite internet it still needed a phone line to send the http requests out which would then be served back via the satellite. I had no idea that two way was now available. That fills me with hope of escaping the landline!
Thanks again for the tip!
30-07-2017 7:54 PM
@7up Won't you then have another problem - that of getting your landlords permission to attach satellite equipment and cables to their building?
30-07-2017 7:59 PM
Concrete a strong 2" pole into the ground (so long as the dish has a good view of the satellites), feed the wires through air vents, no damage caused and no holes drilled...
30-07-2017 8:19 PM - edited 30-07-2017 8:24 PM
Satellite broadband isn't really fit for purpose. I wouldn't wish it on anyone frankly.
It has monstrous latency, small usage caps, aggressive FUPs, and is often highly contended/oversold...
30-07-2017 8:25 PM
Air vents if you can find one and then get a cable through it, rarely if ever have enough space for that drip loop. Nice idea otherwise
30-07-2017 8:36 PM
Potentially a problem yes but lets face it, trees, fences, vans... they're all pretty unmovable and can have things fixed to them.. I've had to overcome a lot of interesting obstacles over the years so have to look for unusual ways of doing things quite often.
The only one that has really got me stumped at present is how to get an electric wire out of the house to the garage. In the kitchen there are electrical points everywhere so i'm not drilling through that wall. In the living room there is a radiator directly above the back door in my sons room so i'm unsure if any pipes are running down the side of the door. I did try a stud / mains / pipe detector (two infact) but both went mad showing everything was there. Apparently even my plastic tool box had live mains cables inside it. The only other thing I could do is lift the carpet and drill down under / through the floorboards and outside that way but thats serious hassle.
30-07-2017 8:51 PM
It's a last-ditch service for those who are on the suffering end of accountants' greed, when someone needs internet access and there's nothing but that or dialup, I'd personally go for satellite, yeah the ping times are terrible (so not good for streaming or gaming), but, better than nowt...
30-07-2017 9:45 PM
Presumably that's what Sky want your box to plugged into a phone line to send them back data.
- General Chat
