Fantastic line stats, because of a fault!
David_W
Insanity rules!  We have a line fault (major crackling on the line) which has dropped my speed way down (but this isn't about that so isn't for the other part of the forum) but my line stats stabilised perfectly, 29 attenuation with 9 SNR, perfect for getting 8Mb and actually better than before the fault developed (14 snr then!).
So how does that work?  My speed is down to 2.5Mb because of the fault, but my stats are great, so I thought 9 was a perfect snr (it's even dropped to 6!), so having a bad line gives better stats?  I would have thought that with a crackly line my attenuation would go through the roof and my snr would, actually I don't know what the snr would do!
Engineers just been here as I was writing this, and put in some device or another which means a reconnection, my stats:
DSL Connection Details
DSL Line (Wire Pair): Line 1 (inner pair)
Protocol: G.DMT
Downstream Rate: 7616 kbps
Upstream Rate: 448 kbps
Channel: Interleaved
Current Noise Margin: 9.0 dB (Downstream), 28.0 db (Upstream)
Current Attenuation: 29.0 dB (Downstream), 15.0 db (Upstream)
Current Output Power: 19.8 dB (Downstream), 12.0 db (Upstream)
All I got to do know is keep my fingers crossed that my snr sticks at 9 when the fault is fixed Cheesy
Out of interest, once the fault is fixed, any way for PN to manually reset my thingymabob, which has naturally dropped:
Current line speed:
3000
James
Re: Fantastic line stats, because of a fault!
We can manually amend it to match the BT one, although it should catch up automatically.
David_W
It looks fixed, waiting for engineer to phone and say its fixed, but again my stats get worse now that the line is better:
Current Rate: 7616 kbs 448 kbs
Max Rate: 7616 kbs 1112 kbs
Current Connection:
Current Noise Margin: 14.0 dB 28.0 dB
Current Attenuation: 29.0 dB 15.0 dB
Current Output Power: 20.0 dB 12.1 dB
Why does my SNR go to 14 when there is no line noise, but 9 when there is?  I thought SNR was supposed to be really high on noisy lines?
James
That's a good thing!
Your SNR is higher because your sync speed can't go any higher (unless interleaving is removed).  A higher SNR is good on high synced lines.
David_W
Ahh I think I see.  if I went Fast Path my SNR would drop but I'd be at the full 8meg?
James
If your connection remained stable, I'd expect it to stay similar.
For the benefits you'd get (minimal!), I wouldn't have thought it worth the risk.
David_W
I was put on fastpath not so long ago, but for some unknown reason a day or so later it had switched back to interleaved.  I still get pretty good download speeds so I'm happy enough with interleaved on, and eventually we'll be on 21CN so I should get pretty respectable speeds from that too.  it's still a mystery how my line stats were so good with a fault so bad it was almost impossible to hear what was being said on the phone.
