Fact or fiction ?
Fixes: 9
Fact or fiction ?
Water that has been previously boiled freezes faster than water that has not been boiled.  Fact or fiction ?
TORPC
Re: Fact or fiction ?
60/40 Fact
Although that is my gut instinct
That said I feel an experiment should be done to make a conclusive answer
Ok after seeing
[quote=http://math.ucr.edu/home/baez/physics/General/hot_water.html]
History of the Mpemba Effect
The fact that hot water freezes faster than cold has been known for many centuries.  The earliest reference to this phenomenon dates back to Aristotle in 300 B.C.  The phenomenon was later discussed in the medieval era, as European physicists struggled to come up with a theory of heat.  But by the 20th century the phenomenon was only known as common folklore, until it was reintroduced to the scientific community in 1969 by Mpemba, a Tanzanian high school pupil.  Since then, numerous experiments have confirmed the existence of the "Mpemba effect", but have not settled on any single explanation.
"The fact that water has previously been warmed contributes to its freezing quickly; for so it cools sooner.  Hence many people, when they want to cool hot water quickly, begin by putting it in the sun. . ."
I am now 70/30 Grin
Edit:
Fixed quote
I would have guessed that it should be the other way around.
Boiling will remove a lot of impurities and doesn't ice crystals tend to form around certain impurities?
Fixes: 62
nanotm
something to do with the molecules being in a more ready state to give off energy when excited (warm) to when there in a more dormant state .....
its something we learned about in secondary school some 20 odd years ago,
interstingly enough its also why on a really cold night if you drive your car with the heating on it will have more frost on the windscreen than if you don't .......
its all about energy transfer
VileReynard
Seasoned Pro
Fixes: 10
This is obviously wrong.
Take two equal containers of water, one hot and one cold.
Just suppose the hot one cools more rapidly.
At some point, both containers will be at the same temperature.
And so the absolute best they can do is to take the same amount of time to freeze.
If this is true I can't see a time difference that is measurable outside a laboratory.
And no way am I going to put hot water in my freezer and expect it to use less energy to freeze it.
Maybe I can believe in a fractional freezing speed difference but it must cost more energy.
TORPC
You do not put boiling water in the freezer
Quote from: gleneagles
VileReynard
Seasoned Pro
Fixes: 10
Quote from: TORPC
but the gist of it was that if you had two wooden buckets of a given size, one containing hot water and the other containing cold water (with precise temperatures specified in each case), and if you exposed said buckets to an air temperature of such-and-such, which one would freeze first?
Now a team of physicists believe they may have solved the centuries old mystery of why hot water freezes faster than cold water.
They argue that the rate at which energy is released varies with the initial state of the water and so calculate that hot water is able to release energy faster when it is placed into a freezer.
Quote from: billnotben
Boiling would not remove impurities, it would actually concentrate any impurities by reducing ( through evaporation) the amount of water. Which is one of the reasons that warm water may freeze quicker. A container of warm water in a freezing environment would evaporate quicker, with a greater temperature difference...therefore less to freeze.
Fixes: 193
Percentage-wise how much faster does hot water freeze?
Does it depend on the volume or mass?
Does it depend on the start temperatures or final temperature?
Forum Moderator and Customer
nanotm
its about the change of molecular structure caused by the act of boiling the water,
if you take two sealed pressure vessels with the same volume of cold water, raise one of them to boiling point and then allow it to cool down to room temperature and then place both vessels in a freezer the one that was boiled will freeze faster, because of the change to the molecular bonds caused by the boiling
its all about molecular state change.....
Quote from: doris
I was thinking particularly of hard water areas and the calcium carbonate content.
