FF 29 and Adblock
Fixes: 20
FF 29 and Adblock
Since I updated to FF 29, adblock is NOT loading at start, I need to refresh the tabs to get rid of the ad's now.
Not sure if it is only with a restored session (as all mine are),
I thought it was strange when I saw some pron ads the other day, a refresh and they disappeared as normal.
TORPC
Re: FF 29 and Adblock
I had the same for about a day after I updated but all is ok now on windows
Correct me if I am wrong
You are using linux
Fixes: 20
Yes I am using Linux, but can't see it being an OS issue, it only happened with the update to 29.
Fixes: 196
Not had this issue on either main PC or laptop.
I'm using Adblock plus 2.6
Forum Moderator and Customer
TORPC
That said
I have rebooted Laptop & cleared a load of carp, that build up in the cache since
I am also on Adblock 2.6
Here are my settings to compare
Heloman
FWIW,  I'm having exactly the same problem.
When I first start  FF 29, the adverts appear. However as soon as I refresh the page,  Adblock Plus 2.6 springs in to life and they disappear.
This problem only started with the update to FF 29.
Like Hairy, I'm a Linux user  (PCLinuxOS).
Fixes: 18
Not using Adblock.... but had to re-install IMtranslator, cos it went missing from the right click context menus....  ( Windows Vista Home premium ).....
Fixes: 4
Heloman
Thanks for that,  purleigh.
Seems the problem is with Adblock 2.6, and we'll just have to live with it  Sad
Fixes: 20
Loads of complaints in the forum there, and the details on the about page are a bit vague:
Starting with Adblock Plus 2.5.1.3778 Firefox seems to start up almost as fast with Adblock Plus as it does without. The only disadvantage should be that Adblock Plus is ready a bit later and the first page loading might still have ads.
Might no might about it it does on the first WINDOW not just the first page!  Shocked Maybe with all the complaints they will put a switch in to disable this "feature"
Nope, just this minute updated to V29, my Adblock is fine without touching anything
Can't say I'm keen on the minimalist icon colour scheme though, and prefer the "back" button on the left end. Off to look through the FF skin theme's
I don't use Adblock at present. Can someone please tell me if it removes the short video ads that are shown on Youtube before the main video starts?
TORPC
I have not seen AD in the beginning of the videos from youtube for a while
You could test to see if any I have linked to produces ADs for you
Fixes: 196
Quote from: artmo
It doesn't for me Angry
@Mav, thanks for that. I don't think it will help me then to install it. It's just irritating to have to watch the ad before whatever you want to watch.
