FF 19 now includes a PDF viewer
Fixes: 20
Just updated to FF 19 and on clicking on a PDF found that the browser opens it in a tab rather than launching my default doc viewer app.
Found this (http://www.theregister.co.uk/2013/02/20/mozilla_pdf_view_html5_javascript/) which explains it.
I am posting in CC as it is a cross platform update and not limited to Linux (or M$).
Razer
Re: FF 19 now includes a PDF viewer
Oh, interesting. Thanks for the notice. I updated earlier today and had no idea. I kind of like it in the most basic sense, but it doesn't appear to have the ability to grab and move the page yourself, like most PDF viewers do. You just have to scroll or use the page numbers. I guess I'll have to get used to it. I suppose also it means I can uninstall Foxit; I don't like the way that's going anyway, so am happy about that.
VileReynard
Seasoned Pro
Fixes: 10
I'd like to disable it.
I can understand that those with Adobe bloatware might like it.
Linux has a builtin small quick PDF viewer which is much better.
Fixes: 20
Depends on what you want to do with it, for most of the online stuff evince is ott, as long as the embeded one can save it then it is fine, and you can open it later with evince/doc viewer/adobe/foxit/why.
Razer
What I'd like to see next is a built in replacement for flash. I'm sick of updating it, especially when it's supposed to be defunct (something about Adobe supposedly not working on it any more, yet they keep updating it Huh), and anyway, it's Adobe, so I would like to be rid of the bloat that Adobe always is. There is also the fact that despite this supposedly marvellous thing that is video support with HTML5, every site I encounter video on requires flash to be installed.
VileReynard
Seasoned Pro
Fixes: 10
I want my pdf's in seperate window(s) - not maximised.
I usually run FF in maximised window(s) - no tabs at all.
Sometimes I want to zoom into areas of a PDF page.
Fixes: 62
Thanks - Firefox is just updating and the first thing I am going to do is disable it
VileReynard
Seasoned Pro
Fixes: 10
Change Applications entry to read:-
Thanks HB for that.  I hadn't noticed it.
Fixes: 224
OS X has had a built in pdf viewer since around 10.2 with no need for plugins.
i'll stick with that as it's very good.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
Thanks Evilfox that fixed it  Grin
Waldo
Quote from: vilefoxdemonofdoom
Or edit about:config:-
Fixes: 62
You need to do both as the about:config option is only half there
You still need the second step to get it to open in a browser window
VileReynard
Seasoned Pro
Fixes: 10
I didn't do the about:config thing and it still works properly (like it used to).
Waldo
Quote from: Oldjim
For those who don't want to view PDFs in Firefox setting pdfjs.disabled to true effectively forces FF 19 to behave as previous versions did.
The first step should remove the option to open in a browser window; in my case Preferences for PDFs reverted to default of opening in Evince.
