F-F-F-F-F-F-F
F-F-F-F-F-F-F
You know that the water companies recommend putting a brick into the toilet to save water? Well, my neighbour did that but the brick just won't flush away!  Grin
Re: F-F-F-F-F-F-F
Ureaka!!
Fixes: 19
Re: F-F-F-F-F-F-F
Quote from: nozzer
probably because there`s not enough water ! Grin Grin Grin
Re: F-F-F-F-F-F-F
Nice parrot shutter!!
Fixes: 19
Re: F-F-F-F-F-F-F
Grin
Fixes: 131
Re: F-F-F-F-F-F-F
As long as everything else flushes away I don't see the problem Lips are sealed Wink
Get ready for a refresher on toilet one liners Roll eyes
Customer and Forum Moderator.
Re: F-F-F-F-F-F-F
Oh poo
scootie
Re: F-F-F-F-F-F-F
Re: F-F-F-F-F-F-F
Quote from: Strat
None come to mind right now, I must have a mental blockage ...
3Mb FTTC
Re: F-F-F-F-F-F-F
What a waste Wink Wink
Fixes: 131
Re: F-F-F-F-F-F-F
Don't tell me this thread is going down the pan so early in it's life Roll eyes
Re: F-F-F-F-F-F-F
Serious discussion has been drained away Wink
Re: F-F-F-F-F-F-F
Thought I would plunge in early ...
3Mb FTTC
Re: F-F-F-F-F-F-F
Best to flush them out at an early stage and try to get to the seat of the problem!
Do we need a white paper on this one?    Crazy
Fixes: 131
Re: F-F-F-F-F-F-F
It's a tissue of lies Shocked
