Examples of accurate news reporting
Fixes: 62
http://www.msnbc.msn.com/id/37177037/ns/gulf_oil_spill
The contraption used by BP was hooked up successfully and sucking oil from a pipe at the blown well Sunday afternoon after being hindered by several setbacks. Engineers remotely guiding robot submersibles had worked since Friday to place the four-inch tube into a 21-inch pipe nearly a mile below the sea.
http://edition.cnn.com/2010/US/05/16/gulf.oil.spill/index.html
Crews re-inserted the tube into the well's riser stack Sunday. The 4-inch pipe is now connected to a ship on the surface, 5,000 feet above the sea floor, and is pumping oil back to the surface, BP spokesman Mark Proegler told CNN.
http://news.bbc.co.uk/1/hi/world/americas/8685969.stm
It is thought that BP's 6in-wide (15cm) tube and stopper could capture more than three-quarters of the leak, although a smaller spill nearby also has to be contained.
http://news.sky.com/skynews/Home/World-News/Gulf-Of-Mexico-Oil-Spill-BP-Says-It-Is-Starting-To-Sipho...
The underwater operation used guided robots to insert the 21-inch pipe, known as a riser, to funnel the oil to a ship at the surface.
"It's working as planned and we are very slowly increasing the rate that is coming from the riser tool up to the surface," BP senior executive vice president Kent Wells said.
Re: Examples of accurate news reporting
Quote from: Oldjim
Title: accurate news reporting
You're obviously a lot younger than your picture if you believe such a thing exists, or ever has.  Crazy
i think oldjim has his tongue firmly planted in one or other of his cheeks on this occasion.
Fixes: 62
The mind boggles  Embarrassed Embarrassed
pierre_pierre
and what did the daily mail and express have to say
