Engineering question...
Fixes: 19
I need to drill a  hole in a section of 15 mm square brass bar... and then tap it for a 6 mm threaded bolt.... do I drill a 6 mm hole, or a 5.5mm hole?
Any offers ? ( as I don`t have a pillar drill, to make sure it is vertical ).....
Fixes: 62
Re: Engineering question...
Fixes: 19
Thanks Jim.... still a bit confused... how do I find the "pitch" of the thread... it is a 6mm x 25mm pan head slot type bolt.
Fixes: 131
A cheap pitch gauge....often included in tap and die sets.
Customer and Forum Moderator.
Fixes: 62
best way is to measure it - distance between 20 threads - although it is probably 1mm as I don't think that metric fine is available at M6 http://www.metrication.com/engineering/threads.html
However - as strat infers above you need to buy the correct tap for the thread
If I read the read right Shutter is screwed if he goes wrong.
What type of brass is it?
jim:green extremely rude typo changed mod:end
Now Zen, but a +Net residue.
Fixes: 19
Yeah.. I am screwed (?) if it goes wrong..  it is brass bar... solid brass.. that`s all I know about it...    I realise that I need to get the pitch of the "tap" hole the same as the pitch of the supplied bolts... however. I do have an alternative.. and that is to drill a 6mm hole.... then, on the underside... drill a BIGger hole, to allow the insert of the 6mm nut to be soldered in place...  a messy solution, but it works if I can`t get it right ! ! ...
Unfortunately, there seems to be some "lateral" and "end" play on the thread of the nut and bolt, so I would prefer it if I can tap, or get it tapped to the correct pitch for the bolt to be a reasonably tight fit...
The bolt will be used a a fine gap adjuster, and may need a lock nut, or some kind of compression spring to hold the adjustment so set...
EDIT EDIT EDIT
I was considering buying this set......
http://www.ebay.co.uk/itm/310926178933?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
but I can`t see a "pitch gauge" in there....
Kevin
A quick Google seems to say that a coarse 1mm pitch is the usual for an M6 bolt, therefore you would need to drill a 5mm hole in brass.
http://en.wikipedia.org/wiki/ISO_metric_screw_thread
Kevin.
Fixes: 131
Quote from: shutter
Sad
Pitch gauge on everyone's favourite auction site.
Fixes: 19
Thanks Kevin....  Wink
Thanks Strat .....  Wink
Fixes: 10
Quote from: Strat
Why can't you politically correct people just accept that there is actually no harm in saying "ebay" ? - What is wrong with saying that Stat? Instead you tell me that its my favourite auction site - which in itself is not politically correct because it is not my favourite auction site Tongue
Come on.. I want an answer! Too many people dodge names of sites, newspapers, TV programs, usernames etc.. it's all getting rather silly when you can't even say ebay anymore.
Fixes: 19
Wow.... that is really going "off topic"...  Lips are sealed
No, that's just going off! Cheesy
Got to agree though, why pussyfoot around? Smiley
Fixes: 131
Correct me if I'm wrong 7up but I believe this was the first time I have used that particular phrase and it will almost certainly be the last.
Please accept my apologies if it offended your sensibilities.
Fixes: 4
Assuming you know the bolt and tap diameters (in this case M6), I've always held the bolt thread against the tap thread, and if the threads match and 'interlock'/'mesh' then it's the correct pitch, and if not you try the next pitch size tap from your tap set !
