Education Education Education
shutter
Fixes: 52
What happened to it ?   When I was at skool... it was Reading wRiting and aRithmetic...or   the three R`s that were the main core of the education system.
I have seen an item on Ebay that I am interested in... done a bit of research on the item`s history./manufacturer etc.
advice is that Genuine items are made from Iron or Steel... and fakes are generally alloy .. always check with a Magnet..
Simple enough   ? ? ?   oh yeah..
so I sent of a Ebay message to the seller..
Hello, can you tell me if the base of this item  is iron/steel, or an aluminium ( non metallic ) if you have a magnet that will tell you !
thanks
Here is his reply......
Hi it’s cast metal. Thanks
Ah well.....  Roll_eyesShockedRoll_eyes
25 REPLIES 25
Fixes: 80
Re: Education Education Education
next question to seller :- Ah, but which metal? Mind you, I don't think you'd get an intelligent answer. Smiley
shutter
Fixes: 52
Well....... apart from the fact that the question was posed in the original message....
so .... I replied to his message.... with this...
Yes, I know that... I want to know what kind of metal.... iron or steel... or aluminium... and a magnet will tell you if it is iron or steel ....... or not...
so far...he has not replied....
Maybe he is trying to find a magnet ! ! ..
Fixes: 80
Minivanman
Aspiring Legend
Seems straight forward enough, but not everybody has a magnet to hand. I certainly don't.
Is there another way to check?
I have not failed. I've just found 10,000 ways that won't work.
Thomas A. Edison
shutter
Fixes: 52
Well, I suppose you could wait a few more years and see what colour the rust or corrosion is.... BUT... looking at the pic on ebay... it could still be either... as there is some brown rust spots on one half , but the front end has got white corrosion on it... indicating that may be alloy
If you can think of another way of detecting the difference between magnetic or non-magnetic metal...please tell... and I`ll suggest it to him !  Cheesy
Strat
Fixes: 515
Steel is an alloy of iron, carbon and various other ingredients.
Pedantic moment 🤔
Customer and Forum Moderator. Windows 10 Firefox 90.0.2 (64-bit)
shutter
Fixes: 52
Oh.dear     Undecided ..... there`s always ONE.....  Roll_eyes
Fixes: 80
There was nearly two, @shutter , but I didn't bother after @Strat had pointed it out.😁
RobPN
Fixes: 7
Make that three @jab1 Grin
Fixes: 80
just to complicate things - and I'm sure @Strat will back me up here - there are magnetic and non-magnetic steel alloys.
RobPN
Fixes: 7
Pedantic moment 🤔
The EU is an alloy of Oireland and 26 other countries.  Grin
RobPN
Fixes: 7
And ISTR that cooking pans made from non-magnetic stainless steel can't be used on inductive induction hobs.
Fixes: 80
Correct, @RobPN , although I've temporarily forgotten the reasons. Been a while since I've had much to do with the physics of it, and most (all) of my experience was in engineering and speciality steel anyway. Although we did use pots and pans while cooking our lunches/dinners/teas, depending which shift we wee on. 😀
Strat
Fixes: 515
2 years in a Metallurgical laboratory leaves a residue of facts in the old grey matter.
