Easy Chicken Recipe
Fixes: 10
Easy Chicken Recipe
Just seen on another forum...
Here is a chicken recipe that also includes the use of popcorn as a stuffing -- imagine that. When I found this recipe, I thought it was perfect for people like me, who just are not sure how to tell when poultry is thoroughly cooked, but not dried out. Give this a try.
1 Chicken
1 cup melted butter
1 cup stuffing
1 cup uncooked popcorn
Salt/pepper to taste
Preheat oven to 200 degrees
Brush chicken well with melted butter salt, and pepper.
Fill cavity with stuffing mixed with popcorn.
Place in baking pan with the neck end toward the back of the oven.
Listen for the popping sounds.
When the chicken's arse blows the oven door open and the chicken
flies across the room and lands on the table, it's done and ready to eat.
And you thought I couldn't cook .....
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: Easy Chicken Recipe
prolly better to stuff its innards before covering it with slippery grease and making a wrestling match of it, unless you want the extra entertainment.
you'll need to reorient the chuck facing out if you want the the dickie bird to land on your plate.  facing away from the door, sure the door will blow off, but the chuck's headed through the back of the oven.
nadger
Quote from: artificer
That problem had also occurred to me - rather glad we spit roast our chickens  Smiley
is that where you spit on the chuck to see if it's cooked?  if it hisses, 'tis done.
Fixes: 68
Jelv,
Interesting, definitely a new twist on popcorn chicken there and not the kind you get from KFC. Hoping to get the barbie out this weekend and I think I might give this a go, beer chicken:
http://www.videojug.com/film/how-to-make-beer-can-chicken
 Adam Walker
