Does anyone still use the jump to feature in forums anymore ??
TORPC
As per title
Just curious more than anything
I will use PN's as an example for the screenshot
Fixes: 192
Re: Does anyone still use the jump to feature in forums anymore ??
I don't think I ever scroll down that far  Wink
Forum Moderator and Customer
Fixes: 62
ditto - I use unread posts
WTF
Hadn't actually noticed it until now  Embarrassed
Fixes: 17
Sounds far to energetic for me, at my age....  Cheesy
TORPC
Quote from: Mav
In that case you appear not to use the Quick Reply either as you have to scroll past the Jump to button to access the Quick Reply Cheesy
Fixes: 62
didn't even know that was there  Grin
Fixes: 192
What Quick Reply - I don't have that?
I usually click Insert Quote then delete it if I don't need to quote anything.
TORPC
And I have only been here approx 4 Months Roll eyes
Here is a sneak preview
Whilst I was editing Oldjim beat me to it Smiley
Fixes: 62
Fixes: 192
Nope - not here Wink
Maybe it's a configurable option Undecided
Edit: What does the Quick Reply button do that the Reply button doesn't?
Fixes: 62
Fixes: 192
Just found it and turned it on - Turned it off again.
TORPC
Goto you profile
Navigate to look and layout preferences =====> scroll down the page & it should be the 2nd from the bottom in a dropdown box
Then click Change Profile for changes to take effect
I see you found it Smiley
TORPC
Wonder what else we may discover on our travels through the PNC Forum ?Huh
