Do you let your rechargeable batteries rest before use ??
TORPC
I have several rechargeable batteries that I have had for years & they are still as good as new, albeit they are in daily use
They are various makes & they range from AAA - PP3's
following my late fathers advice, from when I was little, ( I know, I ain't much taller now Tongue)
I always let the batteries rest after charging, (Stand on the side) for the minimum of 10 - 15 minutes prior to use,
Could that be the major factor, for why they are lasting a long time or am I just lucky ?Huh
Fixes: 238
Re: Do you let your rechargeable batteries rest before use ??
I always thought it had more to do with allowing them to drain completely as well as not over charging.
Forum Moderator and Customer
I also have a variety of rechargeables. The ones in a cordless phone (BT) get charged up nightly and are ages old and good as new. My camera batteries are rectangular in shape and are charged using a charger with a built-in docking connector. These do seem to loose capacity fairly often and always are left charged until the in-use one demands a change. The stand-by charged condition can last for weeks but there does not seem to be any correlation  with their ages.
WTF
It depends on the battery technology: older batteries did suffer from 'battery memory' so if they weren't completely drained before charging, they wouldn't completely drain in future.  Later batteries needed 'conditioning' where the first couple of times they were used, they needed a couple of cycles of completely charged then completely drained.
More recent battery technology doesn't suffer from this.
Doesn't stop me doing a little conditioning whenever I get a new phone, though.
I've never heard of leaving batteries for 10 or 15 minutes before use, but I guess there's some logic to it: charging batteries heats them and heat can affect battery performance.
Fixes: 10
Quote from: Mav
That was for NiCad batteries which had a memory effect. Most rechargeable are now NiMH or Li-ion.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 21
One of the batteries that I had which lasted the longest was a cheap AA NiCd that I bought in the late 80's / very early 90's. It was initially used in a small torch - 2AAs. In more recent years, by itself in a clock and it lasted well in there. I only had to chuck it out last year as it would no longer hold charge.
It was usually discharged pretty well fully before being recharged and could well have been overcharged a touch on occasions.
Fixes: 62
The limiting factor is the number of recharges and what seems to reduce first is the effective capacity on my Eneloop batteries
Fixes: 9
I Have been using the same electric toothbrush for the last 3 years  on a daily basis and it's still going strong, I suspect the same applies to built in rechargeable batteries in a number of other things like tablets etc which are used on a daily basis.
The original post was referring to removal batteries but as mentioned by others the technology has changed and these things are constantly improving as are the items they power which over time have required less power to do the same or more tasks.
Fixes: 21
It also seems to be make dependant as well. I have had cheap rechargeable's that fail out of the box. I ordered 4 and 2 were at 0V when I got them. I also have some 14500's one of which works fine the other is @0.7V and fubared again NEW.
I have several of the newer "ready to use" rechargeables and they seem to be better, all be it at a lower capacity than some others.
However I usually re-charge then store, rarely re-charge and use.
Fixes: 174
The latest I read regarding NiMH or Li-ion batteries is that they benefit from being topped up from about 40% and removed from charge when full.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
nanotm
I've had more DOA's in the last year than before and when I asked why the supplier invariably claims its a problem caused by the new transit rules requiring them to be discharged prior to transit so often times they will be sat in a fully discharged state for weeks instead of half charged as they would have been in the past, and LI-PO seem to be affected by this far more than some of the other types of battery's available
