Digital Tyres
Fixes: 292
Digital Tyres
When were digital tyres first introduced, how can I tell if I have them fitted to my car and what benefits do they offer?
Customer and Forum Moderator. Windows 10 Firefox 68.0.2 (64-bit)
Life is tough enough without adding Linux into the mix.
9 REPLIES 9
Fixes: 62
Re: Digital Tyres
I tried one of those on my analogue tyres to replace the old analogue pump and gauge and it seemed to work OK  Cheesy
Fixes: 292
Re: Digital Tyres
Good to know it's backward compatible then...I might get one.
Re: Digital Tyres
Er! too much thinking in traffic jams Strat...made me  Smiley though...
pierre_pierre
Re: Digital Tyres
made for the winter, all those digital Bytes hold the road
Re: Digital Tyres
Where angles fear to tread...
Fixes: 62
Re: Digital Tyres
are these bits or bytes
and is this a terra byte tyre
Re: Digital Tyres
What about this:
pierre_pierre
Re: Digital Tyres
wonder what size this one takes?
Fixes: 292
Re: Digital Tyres
Looks like something out of Transformers.
