Did you know?
Did you know?
The topic on windscreen dots reminded me... did you know colour laser printers print a feint yellow dot pattern on each page. The pattern is unique to each printer, in effect a serial number which the manufacturers can trace back to the original printer. If you have blue spectacles you can see the dots.
or maybe this should be in the foil hat topic.
Now Zen, but a +Net residue.
Fixes: 10
Re: Did you know?
and scanners have built in software to recognise money being scanned (apparently)  Crazy
Re: Did you know?
Mine didn't but when I tried to scan some money it was Photoshop that coughed up a stop sign.
But the application of a downloaded fix quickly put an end to any objections.
Re: Did you know?
Getting the right ink is such a pain. Wink
Re: Did you know?
Yes, tax discs as well. Tried it once <out of curiosity having heard about it> and it came out really distorted that wasn't circular and wouldn't have passed even cursory inspection.
Still, it doesn't matter now.
Re: Did you know?
Way back, when there were patrol cars around getting the right colour was the main thing.
Fixes: 12
Re: Did you know?
Quote from: Petlew
i had a scanned tax disc pass a visual check by a police officer once.
in fact it was a scan of an expired one, "fixed" in photoshop to make it non-expired and then printed out on a colour laser.
only took about half an hour to do.
don't ask why i have a scanned copy of a tax disc in the car though......
Fixes: 144
Re: Did you know?
I scanned a £1 note ok but not current currency.
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
Re: Did you know?
£1 note - not so common nowadays, but if you grind down 50 pence pieces they make passable 20p coins
nanotm
Re: Did you know?
my scanner adds the word specimen to currency and other official documents if I try and scan them to file on the pc, but if I just scan them to a memory card plugged directly into the scanner there is no watermarking added and the pc doesn't care if I want to then play with those files or indeed print them which I find strange but probably a flaw in security measure that it requires the pc installed program
still I don't have the right grade of paper to attempt producing counterfeits, i'll leave that to the banks to print money that didn't exist the week before /
Fixes: 10
Re: Did you know?
Quote from: AlaricAdair
Shocked
If you're short on 20p coins, send me lots of 50p coins and i'll change em for ya  Wink
Fixes: 144
Re: Did you know?
You must think I was born yesterday...one 20p coin out of a 50p coin Huh
If you carefully slice a 50p coin in half you can make two 20p coins Cool
rhydsnewi
Re: Did you know?
RE codes on banknotes
This was most clearly visible on old "Elgar" £20 notes. The musical score was set up in such a way that the notes marked out a specific code (the same as on US $100 notes) which, as mentioned, would be picked up by Photoshop and the program would refuse to deal with the image.
