Dedicated Hardware
Fixes: 131
Dedicated Hardware
Isn't this taking things a bit far when you can buy a camera specifically to photograph clouds Undecided
And no mention of meteorological use.
Customer and Forum Moderator.
TORPC
Re: Dedicated Hardware
It seems they will not stop at anything to, make a quick buck Sad
Fixes: 225
Do you just get a blank photo if you try to take a picture of anything but clouds Cheesy
Forum Moderator and Customer
Fixes: 62
I assume that the original post was meant to be tongue in cheek as I read the full description  Lips are sealed
Fixes: 131
Sorry Jim Wink
Not much use at night
Night vision up to 5 metres
Most of our clouds are much higher than that.
Quote from: Strat
Used at Japanese soccer matches for cloud control?
Now Zen, but a +Net residue.
Fixes: 131
Ah...those clouds Grin
Thunderclap
Cool Google for "weather web camera" and prepare to see lots of urm... clouds.
* Although for some weird reason, some people think that a weather webcam should be pointing at the ground.
Quote from: Strat
Everything has a silver lining...
TORPC
There is always Cloud cukoo land Tongue
