Danger ... Can you see what's wrong with this Mains Socket Safety Cover ?
Infinity
Seasoned Pro
Danger ...
It has an extra long plastic Earth Pin, and can be inserted upside down......
Opening the lower two  sockets, one of which will be 240v Live
http://www.fatallyflawed.org.uk/
Fixes: 20
Re: Danger ... Can you see what's wrong with this Mains Socket Safety Cover ?
BUT this is the same for any plug surely?
Fixes: 19
That`s really useful.... now I don`t need to go out and  buy a 3 pin plug for my electric drill.... just poke any plug in upside down, and then poke the wires in the other two holes...
Brill... thanks for the tip...  Wink
Fixes: 226
From the OP's link:
Babies of just 5 months have been known to remove socket covers!
Who, exactly, would leave a baby of 5 months unattended to perform such an action  Shocked
Forum Moderator and Customer
Infinity
Seasoned Pro
Quote from: Hairy
Not really...
Quote from: PlusComUK
Danger ...
Quote from: shutter
No, read the above, from the original post
Fixes: 5
I remember as a kid, my parents tried those covers so I used to get a knife and prise them off.
My dad was bad. I remember (back in the day), no new electrical equipment came with a plug and so you had to fit one youself. So my dad would get the two bare wires of something which had no plug, and put something in with a plug on top, so they'd both work.
I remember trying that too then and it worked. Now I realise how dodgy that was.
Fixes: 20
That site goes into great detail about what's wrong with socket covers, which manages to be pretty much everything. But the earth pin being too long wasn't a main problem, it's more that the other pins are too short, and that the cover is usually a pathetic piece of plastic that's not even big enough.
Fixes: 19
Quote from: shutter
Oh dear.... does that mean I will have to buy one of those in the orignal post, then ?
Infinity
Seasoned Pro
British 13 Amp sockets have built in automatic shutters to protect against children poking things in.
    First introduced 65 years ago, they are considered the safest in the world and do not require external covers.
    No responsible national body recommends using socket covers.
    (That includes the UK Government, RoSPA, Ofsted, Child Accident Prevention Trust and Electrical Safety Council.)
    Sockets are made to accept plugs which meet very exact requirements.
    Anything which is not made to the same dimensions as required for plugs may cause permanent damage.
    No socket covers which meet the correct dimensions are available!
    Socket covers introduce a variety of dangers; they make sockets less safe, not more.
UK law requires all sockets sold to conform to the current BS 1363 standard, this is what ensures your child’s safety.
It was originally introduced in 1947 as: British Standard 1363 : 1947  FUSED PLUGS AND SHUTTERED SOCKET OUTLETS.
Maybe the plug sockets are safe but....
I remember when I was very young playing with my parents bedside lamp. I used to take the bulb out, switch on, then put my finger in the socket.
I used to do this many many times.
Thankfully I appear to have grown out of that. Cheesy
Fixes: 226
Quote from: billnotben
I just have to ask...
Why?
Fixes: 4
Because he is really Uncle Fester from the Addams Family !   Cheesy
Fixes: 135
It's quite simple https://www.youtube.com/watch?v=vZOJMZEITzg
The relevant bit starts at 1:20.
Customer and Forum Moderator.
pwatson
Quote from: shutter
No - Just use a screwdriver in the earth socket to open the shutter, poke in the wires and remove the screwdriver.  The shutter then grips the wires and stops them falling out.
Simples!
Fixes: 10
Quote from: shutter
And you don't even need to worry which wire you put in the two holes as it's AC so polarity doesn't apply  Cheesy
