Daily Telegraph website
bertmay
Could someone go to the telegraph newspaper site & tell me how long it took for it to load, also check how long it takes to open a few of the stories.
For me over the past few days it has taken over 5 minutes to open the main page & even longer to get all the links open. It has become so slow I have gone to other news sites without any problems. It seems to be only the Telegraph which has slowed. I have tried at various times of the day to see if that makes any difference, it did not
Bert
Fixes: 62
Re: Daily Telegraph website
effectively instantaneous here - Ipprofile 3000kbps and with nothing cached but using OpenDNS servers
James
Hi Bert,
It took me 7.6 seconds to open the main page. 8.941s to open the BP story & 15.124s to open the Apple tablet story.
Most of that time is waiting for the images to load though.
Same as Jim, virtually instantaneous - and all images loaded with one second.
Fixes: 62
Apple tablet about 1 sec - however I am using Firefox 3.5 with Adblock+ running and it blocked quite a few pictures
4 to 5s per page, over a fibre connection, and nothing in my cache.
3Mb FTTC
bertmay
Thanks for the replies.
All I get is waiting for http;//www.telegraph.co.uk in the bottom bar with the green progress blocks.
Something at my end won't allow it to load as it should. I tried the Mail online & that was instant so I am a bit baffled.
Using IE8 on custom level settings, medium privacy, pop up blocker enabled.
Why is it just the telegraph site.
Any suggestions before I go back to default settings
Thanks again
Bert
Midnight_Caller
Have you added something to your hosts file?
bertmay
I put IE8 back to default settings, now the telegraph site loads as it used to.
I also put www.telegraph.co.uk/ domain onto the whitelist in my security suite.
Bert
Fixes: 62
That last one isn't a good idea - if someone slips something into that site (and it can happen) it could infect your computer if your security suite doesn't check it
bertmay
Removed from the whitelist
Thanks for that
Bert
