DVD to MP3 Converter
Fixes: 51
Does anyone know of a free decent DVD soundtrack to MP3 ripper.
I have a few concerts on DVD and would like to extract these to MP3.
I have tried a couple of shareware offerings but they tend to restrict the number of tracks or time to rip.
I know there are copyright issues but I have read that this practice for personal use is considered acceptable.
Customer and Forum Moderator.
pierre_pierre
Re: DVD to MP3 Converter
Window Media player will rip the track and them Audacity will convert to MP3  - no cost
Fixes: 51
I can find no way to rip the audio off a DVD in Media Player pierre. I can rip music CD's to MP3 in Media Player.
pierre_pierre
What the difference between Audio and Music?  or are you talking about Videos?
my answer is not the simple one, but play the video on One machine with a patch cable from earphone to mic socket on another, then use Audacity to record the sound.  You can separate the tracks in Audacity and save sections at a time (Export to MP3)
avidemux and devede are free apps that may do the trick.
Fixes: 51
Yes pierre it is a Music DVD with movie and sound. There are a few shareware apps about (tried a couple) that will rip the soundtrack off a DVD.
I'm having a look at alternative methods with stuff already installed but I thought there must be someone who has found that elusive perfect app for the job.
Thanks for your suggestions pierre.
pierre_pierre
Looking back I guess it is Video, I have recently been recording the Transatlantic Sessions from BBC4 Videos onto my PVR, then ripping the Audio for the Wifes MP3 player using Audacity.  Works a treat.  I plug the audio outlet plugs on the PVR into the Line in socket on my PC,  You should also have audio out sockets on a DVD player.
Fixes: 51
Quote from: artificer
avidemux looks the more promising...thanks artificer.
@pierre...yes I have but I'm looking at digital options first to maintain quality.
