DVD Decoder
DVD Decoder
Wasn’t sure where to post this so please move if necessary.
SWMBO has bought an old Inspiron 1501 laptop from a work colleague to, primarily, help with the kid’s homework. We tried to play a dvd on it and Media Player gave a message saying that a dvd decoder in not installed. The disk drive is a HL-DT-ST CDRW/DVD GCC4244.
Any ideas on how I can obtain a dvd decoder for it?
6 REPLIES 6
Re: DVD Decoder
Anything here:-
http://www.dell.com/support/troubleshooting/us/en/19/Product/inspiron-1501
You can put in your service tag number to make it more relevant to your particular model.
Fixes: 21
Re: DVD Decoder
From what I remember you need a dvd player to play dvd's on M$ OS's. Try a google for free xp dvd player.
Re: DVD Decoder
Sounds to me like the software to play DVD's isn't on the laptop anymore, this CDRW/DVD GCC4244 seems to be your optical drive where CD's/DVD's go.It's possible you need to install a driver/software from the manufacturer for the optical drive as billnotben suggests.
You might first try a different media player to play DVD's with, I use VLC Player and it's a brilliant player for all file types including DVD's.
It's open source (free) and it's the best media player in my opinion, you can download it here:
http://www.videolan.org/vlc/
Re: DVD Decoder
Many thanks Glenn, works like a dream  Smiley
Fixes: 40
Re: DVD Decoder
Another one you can try .... FREE... is GOM player.... I used it on my old Inspiron... and on this one too..... Plus got it on my Hannspree 10"... I reckon it is "the best"...
http://gom-player.en.softonic.com/
Re: DVD Decoder
I'll second using Videolan (VLC Player) - plays just about anything you throw at it.
