Current Priority Problems
VileReynard
Seasoned Pro
Fixes: 9
According to https://portal.plus.net/support/service/problems/index.php
We currently have no open priority problems
  Roll eyes Roll eyes Roll eyes Roll eyes
Downgraded and closed problems can be found in our Problem Archive.
The last problem was in June (and that was only a test).
Fixes: 4
Re: Current Priority Problems
Maybe they have a problem open ,  to investigate why Current Priority Problems are not been shown. Cheesy Grin
Regards
Mike
Mike
Fixes: 13
No Problem, then ..........................  Roll eyes
rongtw
Fixes: 12
They will update you soon   Roll eyes,,,,,,,,,, obviously they added something that made it go to back of Que
TORPC
It is programmed with the usual speil
"We are looking into it,
That said we have no time scales as that means that we would have to give you personal / details
We need to look in all the wrong places in the 1st instances"
Fixes: 13
Quote from: TORPC
That is standard practice, even you do it...    it rules them out, before you actually find what you were looking for...  Cheesy
TORPC
We are working on Prioritising it
  Roll eyes
Plusnet Staff
Plusnet Staff
Fixes: 159
The priority problem page is something we haven't actually used for quite a while, tbh we should look at either retiring it or updating it to match the way we work problems now.
 Chris Parr
 Plusnet Staff
VileReynard
Seasoned Pro
Fixes: 9
Do you use this one then:-
[It was the same yesterday]
Plusnet Staff
Plusnet Staff
Fixes: 159
Yep, that's still in use. Can you try a single disconnect/reconnect to see if that kicks it into life for you?
 Chris Parr
 Plusnet Staff
VileReynard
Seasoned Pro
Fixes: 9
Fixes: 50
Quote from: rongtw
Another short queue Wink ....we like them Smiley
Customer and Forum Moderator.
Fixes: 13
No matter how "short" the Q.... it would be nice to know what position you were in that queue.... before you actually became "number 1" ! ! !    Lips are sealed
Fixes: 142
Quote from: shutter
Is Ben Wishaw really that short Wink
Forum Moderator and Customer
TORPC
Where is Miss MoneyPenny ?Huh
