Curiosity
Curiosity
If you have Google Earth. Type in Skunk Works (its possible you may need to be viewing in the US with GE first) you will be taken to what was once one of most sensitive areas in the world. The Lockheed Martin aircraft works, where some of the exotic US spy-planes were designed and built: U2 and SR71 to name but two.
However, to the east of the runways are a number of circular areas that look like crop circles and designs, except they're the wrong colours -black and white- but since the area is largely desert crop circles seem unlikely. Out of curiosity, and given where it is, anybody like to guess what they might be?
Re: Curiosity
Just below those circles there are what appears to be hundreds of houses (accommodation for the ex-Lockheed staff?). I suspect that the "crop circles" are exactly that, irrigated areas for growing crops locally for these people. It's a pretty isolated part of the world.
Re: Curiosity
Could well be nozzer thank you. On our numerous holidays in the Canary Islands Black sand and "fertile" irrigated areas are quite common, should have realised I guess.
pierre_pierre
Re: Curiosity
If you zoom right in you can see the irrigation bars and the spray, the one below also has the shadow ling.  a bit bigger than the ones on Lanzarote
Lurker
Re: Curiosity
This is a reasonable enough video of what you are seeing - but at ground level (and in the middle east rather than US.)
