Cunning Linguistics. Split from: Format hard drive without a floppy drive
This thread has been split from this topic
We should all sit on the naughty step for at least a short while for drifting off topic so far!
pierre_pierre
Re: Format hard drive without a floppy drive
forget about the OP [oldage pensioners]- (Thats Me) what about the younger readers?  Roll eyes
Fixes: 186
It's second nature to them Wink
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Quote from: pierre_pierre
[oldage pensioners
Since when has oldage been one word? We meant Old People! None of this politically correct nonsense. Grin
[me=James_H]thinks his tongue is in his cheek, but he's just had two fillings and his mouth is so numb he can't be entirely certain of the position of his tongue...[/me]
Oh yeah, generally speaking OP relates to Original Poster in this context.
HTH (Hope This Helps, or Happy To Help) Wink
Fixes: 21
Thanks for the translation  (james H)  would you be good enough to add them to the ones that (could/should) go into the Abbreviations Forum  Thanks  (short for Thank you)  Grin
To save us writing another one there's already a fantastic glossary of acronyms and technical terms on the usergroup website. I'll ask the mods to add a link to the useful links post.
James
Hmm.
Is thanks actually short for thank you or is it merely the plural of thank?
I'm just randomly pondering Smiley
Fixes: 186
Short for Lazy version of 'many thanks' maybe...who knows
James
Or just more than one "thank" but many thanks crossed my mind aswell Smiley
Reminds me of a guy who works in our warehouse, he's not too clever with numbers, but knows the difference between (in order of quantity)
None,
One,
Some,
Many.
So I guess thanks could be some thanks, or many thanks.
How many thanks do we have? Should we conserve them by only using some thanks, rather than always giving away many thanks.
[me=James_H]starts to recall the grumpy pensioners at Morrisons yesterday. I think they had run out of thanks (and manners - do people also give away 'many manners'? Shocked)[/me]
[me=James_H]also remembers the Forum Rules and reminds everybody (especially himself) not to take this further off topic, otherwise he'll be forced into some thread splittage to avoid drifting.[/me]
Fixes: 186
Quote from: James_H
I get 'many thanks' attached to the bottom of emails 3 or 4 times a day so I have quite a stock.
I usually sign off with thanks so I don't use that many.
If I do run out I have a reserve stock of Regards.
Huh
Ahh, but "many" thanks implies a multitude of thanks, "thanks" as a plural suggests only two thanks. Thanks' would be singular assuming the "s" has been forgotten, as thank without a following pronoun is improper English, Thanks; would seem to be that there are thanks to follow...I'm waiting.
I really must get out more!!
Fixes: 186
But it should be ok to use thank as the following word would be you, eg Thank you.
But if you are replying to someone then the 'you' in Thank you is superfluous as they know it's them to whom you are replying. So Thank should be ok Smiley
Fixes: 21
  Grin  Grin  Grin  Grin  Grin  Grin  Grin  Roll eyes Grin
Actually, I meant "thanks a lot". Not " many thanks" but having read all the different versions, I will add another..... Could it be that it is really the past tense of the word "think".  but then I dont know many people who actually "thinks a lot" either ! ! Grin Grin Grin Roll eyes
Fixes: 62
Isn't it about time the mods started coming down hard on users taking threads off topic  Grin
