Crazy Picture
Crazy Picture
Do you see this from the top or bottom?
Re: Crazy Picture
that has to be escher.  i particularly like his waterfall.
Loombucket
Re: Crazy Picture
Me too - his paintings have fascinated me for years.
I REALLY need to get out more...
Re: Crazy Picture
Yes, its a very clever optical illusion. A friend sent me dozens of these as a .pps file a while back, must see if I can find it.
pierre_pierre
Re: Crazy Picture
loads of them here http://www.mcescher.com/
James
Re: Crazy Picture
Very clever to both Smiley
brad
Re: Crazy Picture
pierre_pierre, that picture reminds me of that scene in Labyrinth with David Bowie. Pictures designed just to mess your mind up!
geewizz
Re: Crazy Picture
Quote from: artificer
I doubt it. Escher didn't have Photoshop.
