Coughs and sneezes spread diseases
7up
Fixes: 14
Use a tissue when you sneeze to catch the germs and stop them spreading. That's what we're told..
So with that in mind, should we be using tissue as face masks? - because if they catch germs then they're obviously FFP3 grade right?
And what happens when it gets soggy and you're still handling it? - do the germs still stay contained?
9 REPLIES 9
Mook
Champion
Re: Coughs and sneezes spread diseases
The use of a tissue is primarily damage limitation.
When you sneeze it comes out at over 100Mph so any 'payload' that's coming along for the ride with travel a fair distance. So using a tissue minimises this distance trapping the 'payload'.
When it does get soggy your hands are covered in germs, but nothing that a proper wash with soap and water won't fix. Wink
Fixes: 188
I seem to recall recent advice that instead of carefully wrapping the results up in a tissue and storing it in your pocket for later that you should deposit it on your sleeve!
Mook
Champion
That's snot the way to do things. Yuk.
shutter
Fixes: 47
@Mook   @Baldrick1
Perhaps this will clear the air ...
https://www.youtube.com/watch?v=dHYd0hdDR8I
Mook
Champion
@shutter I could easily have lost 1m and 16 seconds of my life, thank goodness for the description.
Fixes: 1,182
I didn't even click the link, thanks for confirming my fears @Mook Wink
Mook
Champion
If the description was anything to go by we both had a lucky escape.
198kHz
Fixes: 31
The ocarina sounds the same, but without the yuck factor.
The older I get, the earlier it gets late.
ADSL2+   Billion 7800N
Fixes: 188
It was the title of the tune selected by @shutter that I found a witty if a bit extreme response to my post.
