Cost of RAM
Fixes: 9
Cost of RAM
Seems odd that the cost of DDR 2 RAM is more expensive than DDR 3 RAM.
I Would have thought the cost of an older electronic product would be cheaper rather than more expensive ?
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Cost of RAM
It's probably due to them not manufacturing as many of the older products, therefore production cost is now higher as the batches are smaller.
 Chris Parr
 Plusnet Staff
Fixes: 9
Re: Cost of RAM
As I understand it a number of older Motherboards will not support DDR 3 so you either pay more for DDR 2 or pay even more for a New board that supports DDR 3.
St3
All Star
Fixes: 4
Re: Cost of RAM
You can still get dd2 ram but as you say it does cost a few quid nore now, and the reason is simple ddr2 stuff is old now
btw what you looking for ?
