Correct address
- General Chat
- Correct address
Correct address
13-12-2020 3:20 PM
When posting and referring to your wife what’s the correct form of address ?
For example you could say....’ My Wife’ .......but that suggests a form of ownership...
My partner might be appropriate if you are not married but is it appropriate if you are married.
The ‘missus’ does not sound too good or the term ‘spouse’ ....
Equally there are other terms you can likely think of but not repeated here....
So what’s the correct form....?
NB: You can tell it’s Sunday and I have nothing better to do with my time than post stuff like this, replies will indicate you are in the same boat as me.
Re: Correct address
13-12-2020 3:27 PM
@gleneagles I have better things to do - just can't motivate myself and they all need a bit of brainpower, so I'll answer you. I suppose it depends what you are sending and to who, really. I'm assuming we're talking Xmas cards, so - where you both know the recipients, how about 'John & Jane', or if they are slightly more distant 'John & Jane Smith'?
Re: Correct address
13-12-2020 3:31 PM
`er indoors
Re: Correct address
13-12-2020 4:35 PM
If you mean posting on the forum, I always say either 'Mrs kHz' or 'SWMBO'.
ADSL2+ Billion 8800NL
Re: Correct address
13-12-2020 6:16 PM
You can certainly refer to your wife as "my wife"; there is nothing disrespectful about that. If you want to worry her, you could say, "the current Mrs gleneagles" (especially if she is the first - and so far only - one). 😀
Re: Correct address
13-12-2020 6:16 PM
The other half works for allsorts even Bertie.
Re: Correct address
13-12-2020 7:00 PM
In the Amateur Radio world.... the wife is often referred to as "the XYL" which means eX Young Lady...
( a YL, being an unmarried female)
although some have been known to refer to her as
"The Station Manager"..... ( amateur radio station, that is..... )
Re: Correct address
13-12-2020 7:21 PM
'The Mrs' works for me, but not literally you understand. 🙂
My mother was always called 'the old girl' by Dad but I doubt that would go down very well these days.
Don't limit the friends you haven't met with arguments you'll never have.
Re: Correct address
13-12-2020 7:22 PM
Mine is sometimes referred to as the diary secretary !
Re: Correct address
13-12-2020 7:33 PM
Mine is referred to as Management.
Re: Correct address
14-12-2020 6:52 AM
I would have thought the answer was obvious..?
The Boss 😁
Re: Correct address
14-12-2020 9:46 AM
Er indoors 😀
Re: Correct address
14-12-2020 10:00 AM
My friend refers to his as 'the chief'. 🙂
Re: Correct address
14-12-2020 1:16 PM - edited 14-12-2020 1:17 PM
@7up wrote:
Er indoors 😀
Copy-cat...... see post number three ! ! !
Re: Correct address
14-12-2020 3:42 PM
@Mayfly Most bosses Ive had dont do any work so not really appropriate!!!
