Condom for your USB
rongtw
Fixes: 12
Condom for your USB
Cheesy worried about inserting your USB
well here you go  Wink http://www.dailymail.co.uk/sciencetech/article-2734865/Always-use-protection-6-USB-condom-stops-hack...
alanf
Re: Condom for your USB
£6? For £5 one can charge up 4 devices from the mains.
http://www.maplin.co.uk/p/maplin-4-port-usb-travel-mains-adaptor-n99hr#
rongtw
Fixes: 12
Alan i think you got the wrong end of the stick ,, its a USB security device not a charger  Huh
TORPC
For those that haven't quite woke up yet, & reading with 70% -80% sleepy eyes
These connect between a device and the unknown USB port, effectively severing any data connection but linking up the power cables
nanotm
I'm amazed its taken them this long to figure out this sort of thing is required .....
I've been using portable battery device chargers for that reason for some years now rather than risk compromising my devices .......
Fixes: 226
Quote from: alanf
That looked too good to be true and it was Sad
Discontinued item and nowhere locally has any left in stock Cry
Forum Moderator and Customer
pwatson
Just use something like this - No idea what the chip is for in the one featured in the article...
alanf
Quote from: Mav
Sorry., I didn't spot that. There is a £5 clearance 1xUSB & phone charger but that comes with a UK 3-pin plug. Still available in some stores.
http://www.maplin.co.uk/p/maplin-5-in-1-multi-phone-and-usb-charger-n99gw
Fixes: 226
No worries Smiley
Presently I have a 7-way USB Hub plugged into the mains that I use to charge both the mobile and tablet but it's very slow at charging most of the time and even slower when both are connected.
Quote from: rongtw
Sorry, but that does seem a longwinded way of disconnecting the data lines in a USB cable!
The eBay offering does the same for a fraction of the cost. Using a mains charger is more effective than a USB port!
In fact, a USB port cannot charge an iPad!  Cheesy
Geoff,
York.
