Computing nostalgia
Fixes: 10
Computing nostalgia
Prompted by this post http://community.plus.net/forum/index.php/topic,74056.msg590655.html#msg590655
I'm old enough to remember but was a programmer, not an operator - and our's were ICL System 4/70 and a 4/72 which used the same machine instructions. Hence the prized possession which lurks at the back of my desk drawers.
How many people here could explain (without looking it up) what a BXLE does and how to use it?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 135
Re: Computing nostalgia
I've looked it up and I'm still not clear Embarrassed
Customer and Forum Moderator.
MrC
Sheer and utter guestimate - Branch and Xor if LEss than?
Mike (did a small amount of 360 assembler back in the mid-80s)
Fixes: 135
Oh it's a conditional instruction Undecided
Fixes: 10
Quote from: MrC
Close! Branch on Index Low or Equal.
Horribly complicated to use (but very efficient) and generally only used by clever dicks who were trying to show off or by most programmers just once to be able to say they'd used it. If you were a maintenance programmer and came across it you would groan!
MrC
Smiley I only did a very small amount of IBM assembler; most of my commercial programming was COBOL74/85 on Tandem before I moved over onto Tandem application and system support, and then onto Unix and then network applications and security.
Now I drive trains for a living and it all seems a world awaySmiley
Mike
